Results 1 to 7 of 7
    Oct 2020
    Kent
    37
    Ford sierra hubs
    Hi all,
    I'm after some front ford sierra hubs. I have had an issue with current hub where the spline looks stripped.
    Unless someone has another option, I will need the two front hubs for a 1992.
    Aaron
    Mar 2009
    liverpool
    619
    Hi, splines on the front? The rears have splines. Do you mean the thread on the front hubs?
    Mar 2016
    Brighton
    52
    112
    Hi I might have will look tomorrow ok roy
    Oct 2020
    Kent
    37
    Hi philbrad73,
    Yeah the thread on the front hubs. Unfortunately put new studs in the front and over tightened them and the spline on the nuts and hub have gone.
    And thanks Royhuntsman
    Mar 2009
    liverpool
    619
    Yes, understand which splines you were referring too now. D W classics in Liverpool breaks a lot or Sierras. I know on eBay they currently have a full disc rear end so might have the fronts as well?
    Mar 2016
    Brighton
    52
    112
    Hi aaron give email I can send some pic ok and it 4 stud ok ?
    Oct 2020
    Kent
    37
    Thank you ill check them on ebay.
    Thanks Royhuntsman, I'll send you a pm.
