Results 11 to 19 of 19
    Mar 2005
    1,203
    I've had a fuel smell in the boot for a long time, but no obvious leaks. I found out last week that the fuel pipes weren't the right spec and the ethanol in modern fuels was rotting them from the inside. Aside from the fuel pump & internal filter filling with bits of rubber I did wonder if the petrol smell was due to these pipes too ?
    Since they've been replaced the smell is reduced, but this could also have just been a leaky joint getting fixed during the swap.
    Either way, do check the spec of your hoses, I'm glad I avoided a breakdown and a towtruck.
    David (AKA Firestarter29)
    Lead, follow, or get out of the way.
    562
    Let me get this right, your 'handle' is Firestarter and you had leaky petrol pipes!!!!!!
    Seriously though, you are spot on, those substandard/ethanol intolerant pipes are a massive risk.
    Mar 2005
    1,203
    I’d lost track of when they were changed, not as recent as I thought and was alerted when the fuel pump became very noisy and I lost most power for a minute, then it came back, so I got the pump checked....
    I’ve got an 1800 mile trip around Scotland in May so glad to have found it now, close to home, in dry weather.
    1,950
    Quote Originally Posted by Firestarter29 View Post
    You’re right there David. I had a braided piece of hose going to the carb. Started up after the winter and fuel was peeing out all over the manifold. That certainly grabbed my attention! Good job I did my “pre-flight” under bonnet checks before setting off.
    Phoned Brasscraft and whoever I spoke to was very helpful. They don’t supply a seal but can supply a replacement vented cap. As he pointed out because it’s vented to let air into the tank it will also let a certain amount of fumes out. I guess it all depends on what is “normal”. My filler neck is vented back into the tank with a short rubber tube connector which I should replace in case it’s perished. As with the filler neck hose itself. If I could find a source of nitrile rubber I could make a replacement cap seal then that’s all the culprits covered.
    Mar 2020
    Fleet
    30
    lol, i didnt realise the 'back to the future' reference, and I am a big fan.
    Brasscraft:
    Prior to setting up Brasscraft, Cris Glover was employed by Panther cars to create the Brightwork for this high end market. Following on from Panther cars he worked at Rapport Armalite and was involved in specialised vehicle construction.
    Cris Glover's specialised work includes working on the Spanish Pope mobile, Chitty Bang Bang for the stage production, and manufacture of parts for the vintage restoration market.
    Mar 2005
    1,203
    A nitrile rubber glove ? - marigold rather than surgical style ? Depends how thick you want it.
    1,950
    Don’t think a Marigold would be thick enough David but thanks for the suggestion.
    May 2020
    west sussex
    An issue on my IVA test last week was strong smell of fuel in boot (tank fuel to brim for test).
    Two testers spent some time looking for any sign of fuel leak, but there wasn't one.
    Conclusion was that the fuel tank was not vented correctly to outside of vehicle, there are two tubes in top of tank, one is fuel pick up the other to vent fuel tank.
    I just need to run pipe from tube that's next to fuel supply pipe down and out through a tight fitting grommet.
    9,438
    Quote Originally Posted by TurboFreak View Post
    sniff your copper pipes where they exit/enter the tank - you may have a hairline crack. Well known issue.
