Results 1 to 10 of 10
    Jul 2018
    france
    XJ6 front & rear disc bolt pattern
    Hi everyone, i'am searching with no success the front and rear bolt pattern of xj6 discs to do my homework and machine my 7075 HAT, if someone has this info it will be very helpfull
    3,834
    PCD:*5x120.65*(5x4.75)
    Jul 2018
    france
    Thanks for the fast response. I think this pcd is the one of the wheel studs. What i am looking for is the pcd of the disc fixations on the axle (5 bolts fronts, 4 on the rear on the IRS side that seems to be on a rectangular pattern).
    737
    Can’t give you exact figures but can (more or less) guarantee that the front disk mount PCD is not the same as the wheel mount PCD.
    i made sure me spacers for my discs and they don’t fit the wheels.
    They didn’t fit on my Mercedes wheels but can’t remember what that is. I’ll try and get a measurement tomorrow.
    Dec 2002
    Carpark of Unearthly Delights (Sussex Division)
    676
    I understand and you'd have to confirm a 121.20002 front disc has the following spec
    (from a manufacturer's drawing of unknown origin)
    Outer dia:284.0mm
    Height:60.5mm
    Nom thick:24.2
    Min thick:22.9
    Hub reg:82.6mm
    Bolt size:11.5mm
    Bolt PCD: 5x111.12 mm
    Weight 15.97 lbs
    Hopefully get you pointed in the right direction
    Richard
    "We're going to need bigger brakes"
    Jul 2018
    france
    Thanks you give right info as measures from number 1 to 2 or 1 to 3 bolts confirm your numbers. I assume pcd is on a 4.375" pattern.
    For the rear i ve done search on spicer parts but for now not found right u-joint flange. My measures are 61.3mm and 73.1mm Bolt rectangular pattern...
    Jul 2018
    france
    Some news : front hat have been CAD designed with these pcd numbers. Before 7075 machining, i've 3d print an abs part to verify all my clearance measures to the wheel and confirm caliper mounting bracket design, pics attached.
    Need always info about rear jag irs u-joint flange "rectangular" bolt pattern, if someone can help or give a part ref ?
    Dec 2002
    676
    I did something similar
    Richard
    Jul 2018
    france
    Nice ! Is this custom made hat ?
    Dec 2002
    676
    Glad you approve. It was easier/faster to have them made by http://www.reyland.co.uk/ compared to turning them, setting up the mill and then having them anodized. Martin Hadland is the guy to speak to if you're interested. I did make the caliper adapters as they needed a bit more thought than the bells.
    Richard
