Results 1 to 10 of 10
Thread: Maximum power
    Dec 2019
    amersham
    265
    Maximum power
    My IVA form is asking for the engine maximum power and the engine speed at which it is obtained. Well i know my engine is basically 350 BHP more or less a standard small block.
    But at what engine speed maximum power is achieved i dont know. Does anyone have a rough guide as to what it might be.
    10,351
    It depends on your engine spec.
    The main thing to note here is:
    The IVA noise test is based on this figure.
    52
    422
    Is the IVA noise test at 3/4 the RPM of maximum power? If so, perhaps maximum power RPM should be 4/3 the quietest RPM (excluding zero RPM, of course).
    Jun 2016
    Nantwich Cheshire
    387
    Standard SBC's redline at about 5000rpm. Max power will be a bit less than that. I think I read somewhere that 4850rpm was a reasonable figure to use for max power rpm.
    Dec 2019
    amersham
    265
    Thanks Incey
    If I assume nobody really wants to take it to the red line of 5000 rpm then a figure around 4800 seems realistic, I don’t want to go to low otherwise it gives the impression that the car produces high decibels at low revs, anyway the Iva inspectors must have a good idea of what is normal for this type of engine.
    May 2003
    Hampshire
    187
    Quote Originally Posted by methoni View Post
    Thanks Incey
    you need to ensure you get this correct as it affects the rpm at which the noise test is performed, so the lower rpm max power is produced increases you chances of passing the noise test.
    google is your friend, I found a power graph on line for a crate 350 190hp engine that had max power at 4400 rpm -Street Muscle magazine article.
    there’s another showing max hp at 4000
    passing the noise test at 75% of 4000 (3000) will be easier than passing at 75% of 5000 (3750) .
    there are also other factors that can increase the noise like engine timing so check that as well.
    Roger
    RamSC 351 Cleveland
    on the road 20 years- nearly finished
    Jun 2016
    Nantwich Cheshire
    387
    Have you got AK Side pipes?? If so give at AK a bell. They should be able to advise accordingly.
    1,668
    Rogar is spot on as you dont want to have to over rev the engine if your max power is lower.
    If you have as much information of the camshaft and pull a power profile will be a good indicator. A build receipt of the engine, date of engine, with cam power profile will really make thinks easier as evidence on the day. The more paperwork backs your case and will alleviate any doubts by the inspector.
    Dec 2019
    amersham
    265
    Good idea, I’ll talk to Jon at AK to see what he recommendeds
    May 2020
    west sussex
    89
    I put my max revs as 4600 on my tuned SBC that had hot cams and bored out from 5.0 to around 5.4.
    I put power as per standard 5.0 SBC which for the year of engine was 200bhp... this was not tested or questioned by IVA testers.
    They admitted they thought it probably wasn't going to pass Db test, which was done at 3200 revs, but it just passed with reading 98.5.
    If I had been tested on about 5400 revs as max power it would have failed!
    Good luck with IVA
